My hardware setups and links
do you mind to provide your settings with 2.012b ? (if you upgrade of course)
openhd-settings-1.txt (33.6 KB)
thanks a lot
Is it for ffsplit ?
PS : I will receive soon the lens you recommended
Not for split (it’s for pi camera) , but I’m using it as is, just change the frame rate to 59.9
Hello
I believe that thanks to Evo we don’t need anymore specific settings for Fire Fly split 4K ?
Yesterday I plug and play( ffsplit, pizerow2, asus aC56…) and verything was fine
I disable the adaptive bitrate for FF split, and set a fixed bitrate. Usually flying long range, I use mcs1 in EVO.
