I had some spare parts leftover from building and made a mini version with a cheap pan/ tilt assembly normally used for fpv cams and installed a small biquad antenna on it. I used bluepill (STM F103) and uart for telemetry.
hi team:
sorry for open this topic again.
i also face issue, the heartbeat show good but seems no GPS massage send out not sure what mistake for my setting?
i use INAV the GPS information show good and UART1 for mavlink telemetry output base on 57600 speed.
is any one have same issue?
hello
is anyone still running with this post?
im needing some help please
Hi there. I attempt to build that tracker and even i have esp32 board like yours, good mechanics but i’m stuck due to Arduino libs failure when scratching to stone (no such file or directory e.t.c). Please tell me how did you solved the problem.
UPD: Problem solved just update ESP lib https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Hello im trying to use esp32 wemos lolin32 with oled display and i cant find the correct de board to use It and compile It and i cant find the correct pinout
Somebody has use this board and what variant have you used?
