Hi, hardware list?
…Air
Raspberry Pi Zero + (wifi Card max 200mw Page Not Found - Aliexpress.com) + Antenna 2dbi
…Ground
Raspberry Pi 3B+ (wifi Card max 200mw Page Not Found - Aliexpress.com)+ (Antenna 23dbi 78.03€ 50% OFF|60KM Long Range FPV Antenne 5,8G 5,8 Ghz 23dB High Gain Flat Panel Antenne Mit RP SMA Verlängern Kabel für FPV System|flat panel antenna|fpv antennaantenna 5.8g - AliExpress)
…Settings…
FREQ=5320
DATARATE=2
VIDEO_BITRATE=auto
BITRATE_PERCENT=80
WIDTH=1920
HEIGHT=1080
FPS=50
Thanks!!!
how do you capture the video and put it on windows?
aww yes… thank you …
Hi, @Tree_Orbit!
The antenna from your setup has single output, but WiFi adapter - two. What is the right way to connect the antenna to RTL8812au WiFi adapter?
