I have a question. I want to set a high bitrate for a more detailed picture. Increase data rate and bit rate. But the higher the data rate, the lower the range. Using the high bitrate and 22dBi patch will I go further than the 17dBi patch? Let’s say with a bitrate of 12-14 megabits with a 22dbi patch, will there be a range of 5-10 km?
[image]
I think, yes, it should work.
Hello knputyi,
Little off topic. The efficiency reading of 58mAh/km on the above picture does not seem to be right. Its around 128mAh/km. 6621/51.6 = 128
That’s a momentarily calculated efficiency, not for entirely flight. It changes continuously.
