I did not like the antenna tracker (cases) on thingiverse, so I remixed this one which can easily be mounted to the “cheapeveryonehasitalready - Tripod”:
all the files are available here:
Antenna Tracker Mechanics by SLOWY - Thingiverse
in extensiont to the printable parts you gonna need 2 ball bearings:
35x17x10
and
22x8x6
also 2 (MG996 - sized) 180* servos, M3 screws, washers and standoffs.
Do not use the servos from the pictures, I found various problems with them and gonna switch soon.
It uses this project for the electronics:
if you want to use this with a WiFi connection make sure to visit:
as dr0nemrc made some serious improvements to the FW.
Hope you like it ![]()
