hello folks! 1st time post here…
i’m building a crawl-space inspection rover and i’m very interested in OpenHD, particularly after a Walsnail/CADDX VTX literally caught on fire while bench testing, even though it was being cooled by a fan
however, i’m pretty lost regarding hardware selection for an OpenHD system
my situation…
- if it matters for firmware flashing, etc., i run only Linux
- short range, color, good quality HD video transmission (1080 is sufficient)
- field monitor is a Lilliput A7S 7" Full HD Monitor (16:10 aspect ratio)
- latency is less of an issue - sub 250 ms should be fine
- low light environment (artificial lighting will be employed)
- i’d like to be able to record still images - if possible, then recording video is optional
- control (both Tx and Rx) is provided by a RadioMaster Boxer (2.4 GHz, ELRS)
i’d like to keep the setup as simple as possible while still providing great color video quality - all i need at this point is advice for the hardware/software for video transmission/receiving (SBCs, camera, etc.)
