Hi, I’m building open HD and have a test setup working.
I have video, full osd telemetry and bi directional telemetry to mission planner working as it should (with a question on its connection) but I have seen that there is an option to display a map in open hd’s osd, does that option work and if so what steps are required to have a working map please?
My other question, about mission planners connection is regarding TCP/UDP.
I can ping my ground Pi’s ip just fine but I cannot connect though mission planner using TCP, It fails every time but I can connect via UDP and everything works as it should.
I googled the difference between TCP and UDP and know about the error checking and correction of TCP vs no checks but a faster connection with UDP but is it really a concern?
I won’t be flying using open HD for rc control and will be running a separate rx and only using open HD for video, osd and the bi directional connection to mission planner.
Is it OK to stick with UDP or should I troubleshoot the TCP problem?
Thanks, Steve.
