That is a super clean install, very nice! I’ve crammed my share of parts into a NG, never thought you could get a Pi0 in it, much less a 3B.
Are you using OpenHD for RC then? The NG is one slippery little ship.
The pi 3b is almost totally stripped so it sits flat and weighs much less. It actually fits perfectly, just a bit of foam underneath
Yes, using openhd for rc
I am actually running into issues with my matek gps/compass. I keep getting warnings/errors when arming of efk3 inconsistancy and some number of degrees. I think its related to my compass and interference. I have had a hard time getting good compass calibration. I already lowered the “fitness” requirement of the compass. I also tried another gps/compass. Now I think I have to carve up my wing some more and move the compass even further out…
I had tons of problems with my compass, in fact I had problems even when I moved the GPS away from it, because Ardupilot had calibrated the compass and accounted for the GPS being nearby, and I changed it and messed it all up
Curious as to why you are using a compass on a wing/plane. I’m not an expert by any means, but I’ve read that a gps is good enough, and is actually all I’ve ever used to successfully utilize the different modes (RTH, cruise, navigation, horizon, etc.) in INAV on my wings, maybe Arduplane is different though. I believe in INAV for a quadcopter a compass is necessary for the navigation modes to work, which is why I’m still using Betaflight on my 5" quad. I had a huge problem finding a spot for even the gps to work on it, I would guess adding a compass might not be possible.
“Accurately setting up the compass is critical because it is the primary source of heading information. Without an accurate heading the vehicle will not move in the correct direction in autopilot modes (i.e. AUTO, LOITER, PosHold, RTL, etc). This can lead to circling (aka “toiletbowling”) or fly-aways.”
That is for a copter, not fixed wing. In both inav and arduplane, therr isnt any need for a compass. I use heading hold in both on different birds and it works perfectly, as long as you are moving, all it needs is gps to keep proper heading
For arduplane, it also will try and use the accelerometer for heading.
Put a Pi HQ cam in the nose. I took the HQ cam down to the pcb and then just glued on an M12 lens mount. Works nicely. I built the area around the cam up with scrap foam to keep it clean and aerodynamic. I need to fill it sand it a bit…
