OpenHD 2.0rc16 is now available, this is going to be the last release candidate before 2.0.
Highlights:
- QOpenHD has a settings file now, let the ground station boot at least once and then you can edit
/boot/qopenhd.conf - Fixed the upper/lower bars in QOpenHD
- Add detailed Mavlink telemetry stats in the lower right of the status panel
- Automatically enable Mavlink telemetry messages on Ardupilot flight controllers (may work on PX4 as well)
- You no longer need to edit Ardupilot’s SRx_EXTRA parameters like the OpenHD wiki says
- Add a simpler speed widget
- Fix
openhdvidscript - Add setting to force plain 802.11 data frames on Realtek cards (useful for 8814au)
