This is my test setup:
But I have some trouble with the display on my LCD screen. It seems that not the whole display content is shown:
I’ve changed these parameters in “config.txt”:
# uncomment to force a specific HDMI mode
# 640x480
hdmi_group=1
hdmi_mode=1
Are there other parameters to be changed?
See if your monitor has a way to disable overscan, otherwise you may have to change some of the settings in /boot/config.txt
Seems to have influence on display. I put a # here (in config.txt):
#disable_overscan=1
Now it looks like that:
I’m able to see all OSD information. But video is no more full screen. I assume I have to find proper settings for…
overscan_left=...
overscan_right=...
overscan_top=...
overscan_bottom=...
Closer, for reference the tops of the widgets at the top of the screen are supposed to be just a few pixels away from the edge, and the openhd logo goes right in the corner.
This setup works fine for me:
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
overscan_left=25
overscan_right=25
overscan_top=25
overscan_bottom=25
# 800x600 Fatshark HD1/2/3 (4:3)
hdmi_group=2
hdmi_mode=9
Screen looks like that:
I figured out that I’m able to place and scale all elements (connecting a mouse on ground station RPI). By that I was able to go back to stock setup of config.txt. I just needed to deactivate (or acivate?) the parameter disable overscan:
#disable_overscan=1
