Hi, I’d like to use the expansion bay of my Taranis X9D as the interface to the OpenHD ground station for RC control. This bay provides power and a PPM signal. Is it possible for OpenHD to accept this PPM signal or can only the USB interface be used to receive RC control signals?
Oliver
no…
you could try a ppm to usb converter off ebay or make one
I use the project above on my old 9X transmitter for sims on the PC. I have not tried it on OpenHD but it does appear as a HID so it should work.
Sorry I gave you the wrong information I just had to repair my ppm to usb and found that the link I posted is not the one I used
this one GitHub - wireless-rc-adapter/wireless-rc-adapter: 🎮 Arduino USB-Joystick adapter for RC receivers with PWM and PPM modulations up to 8 channels. works really well
sorry
Yes, this works great. I got it to work with PWM instead of the PPM, with an Arduino ProMicro and the RX.
Since I’m trying to use OpenHD for a rover, I wanted to have a car “pistol” transmitter instead of a stick radio.
My only problem is ch5 is a default button for gamepad config and it seems buttons do not work for the OpenHD.
