Couple questions:
What is the max bitrate people are getting with these setups?
What is the latency from just the link?
I was curious because with DJI doing 50Mb, if this can get that bandwidth you could simply run an uncompressed 480p60 stream. This removes any encode/decode latency and complication. If you want to get a little fancy you could then implement some AI upscaling on the recieving goggles where it is easy to add large and high power devices.
