Hello, I am new to this and want to set up OpenHD. Before doing things with all at once, I wanted to test things one at a time. Following the wiki, I downloaded and flashed the 2.0.8 buster image using etcher. It flashed successfully. I have 2 pis setup, one with camera, one without. When I put the fresh SD card, is the pi supposed to boot up to a desktop or command line? All I get is a blank screen. Once I remove the OpenHD SD card the pi shows a video signal. I tried with multiple SD card and redownloaded the image file and same thing.
I’m not sure if I missed something. Any help would be appreciated, thanks!
I downloaded the buster version as I am using raspberry pi 4. At least I know now they are both supposed to boot up with some kind of video signal. I don’t have an extra wifi dongle attached. I was planning on testing with the internal wifi first or wired if possible. Would that be a problem?
The pis work fine with a raspbian image. It’s just the openHD sd card that has ever caused that behavior for me. Should I try an older version of OpenHD? if so, any version you recommend?
The 2.08 is the one I tried originally, multiple times, multiple downloads, multiple SD cards, and multiple raspberry pis. Neither of the HDMI ports make a difference. The only common denominator seems to be the computer I flashed with and etcher. Regular raspbian images work fine though. I will try to flash with a mac through dd and see if there is a difference. I will reply with the results.
I just flashed with a mac twice and same result using DD. Once with the r before the device name and once without. I’m really at a loss here. I’m not sure what the problem could be. Does SD card size matter? I forget if I tried a 8GB one. I’ve been trying a 64GB one and I think I tried a 32GB one.
Update: I just used a new 8GB card and same result. My only thought is maybe the SD card is expecting a device that is not there and it doesn’t boot? or somehow the Images I download become corrupted? I downloaded multiple times on my windows machine 2.08 and 2.0.10 and on my mac, so that is hard to believe.
