do you have any idea what i do wrong installing qopenhd on my rpi
I just did curl -1sLf ‘https://dl.cloudsmith.io/public/openhd/openhd-2-3-evo/setup.deb.sh’ | sudo -E bash
and
sudo apt-get install qopenhd
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following additional packages will be installed:
gst-openhd-plugins
The following NEW packages will be installed:
gst-openhd-plugins qopenhd
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/17.6 MB of archives.
After this operation, 43.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database … 278487 files and directories currently installed.)
Preparing to unpack …/gst-openhd-plugins_2.3-evo-03031839_armhf.deb …
Unpacking gst-openhd-plugins (2.3-evo-03031839) …
dpkg: error processing archive /var/cache/apt/archives/gst-openhd-plugins_2.3-evo-03031839_armhf.deb (–unpack):
trying to overwrite ‘/usr/share/gstreamer-1.0/presets/GstIirEqualizer10Bands.prs’, which is also in package gstreamer1.0-plugins-good:armhf 1.18.4-2+deb11u2+rpt1
Selecting previously unselected package qopenhd.
Preparing to unpack …/qopenhd_2.5-evo-202309130127-d41f457b_armhf.deb …
Unpacking qopenhd (2.5-evo-202309130127-d41f457b) …
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
what do i wrong?
Trying also compilation but run out of free memory
Best regards
Kris
