I’m trying to modify openhdvid python script adding the possibility to take picture every X seconds on 2.0.8 version.
The script works well when I test it manually, but doesn’t start at boot. I can’t find any logs.
The modified script if someone would try and tells me what’s wrong
https://drive.google.com/file/d/17FzDLTnWy9J19JNfO446cpfysYlGdiZa/view?usp=sharing
It also optimise the resize of video in case of air record.
You have to add this text in the EXTRAPARAMS in the file openhd-settings-1.txt
“–timelaps /home/pi/timelaps.jpeg -wtl 2048 -htl 1088 -stl 1”
with timelaps the path to save images
wtl : width of images
htl : height of images
stl : time in seconds between each images
You also have to activate ENABLE_OPENHDVID=Y
You should also have to increase GPU memory in /boot/config.txt file
