I’m looking for a small, inexpensive, short range wifi card for 5.8 for a microquad and thought I’d give this Anewkodi adapter a try (has a 8812au chip). Well, the camera picture works fine (even out to around 400 ft, which is the farthest I’ve walked), but no telemetry, no signal strength (just stays at preconnection -126 value), no airpi %/temp, the only thing coming back to QOpenHD or my goggles is video bitrate and the number of lost/damaged blocks. If I switch and put the AC56 back on the airpi, all telemetry, everything works which leads me to believe the settings are ok, and that it’s something with the card. So, is it just too much to expect from such a little thing, or is the combination of this on the air side and AC56 on ground just not compatible? Any other little adapters that can be recommended?
