We encountered an issue while using QOpenHD with OpenHD:
The parameter AIR_RECORDING_E cannot be changed from disable to enable, which prevents video recording from starting.
The system shows 0 available storage for video files.
Upon checking the SD card, we found that the original 64GB card is only recognized as 343MB.
Could you please advise what might be causing this issue and why the recording function cannot be enabled?
