USB camera tutorial
https://openhd.gitbook.io/open-hd/advanced-setup/using-only-a-usb-camera
I am still strugglink to use an USB cam only on air (no picam)
I followed but the instructions but still not working
Do I need to apply the gst… line also in ground ?
thanks
the usb pipeline is quite tricky to configure… anyway the configure file MUST be the same both on ground and air
