Using an ethernet network adapter?
Afternoon all. Thanks for all the info over the years. Finally close enough to start asking questions.
Would it be possible to use an ethernet based wifi adapter that has a compatible chipset (something like a Ubiquiti Bullet/Nanostation) or is there something necessary about the USB connection that OpenHD requires?
I have a Wifistation floating around, but using a Bullet on the ground would make for a more robust solution in my eyes.
Thanks!
-Steve
