Hi, I need your help. I replaced my my old camera with VEYE mipi 327E on my Air PI Zero. When I flash OPENHD on a memory card, insert this card in Air PI, it works from te first boot. It may not work on the second boot or later on. The air pi starts and shows OSD working but the screen is black - no video is shown. My VEYE camera works perfectly with Air PI 3A.
Please help !
Did you update the config file with un-commenting dtparam=i2c_vc=on?
Thank you very much for your advice. I’ll double check if the problem is in these settings.
Hi, I managed to solve the problem. It was a ribbon cable of the camera that partly broke and the camera was not connected. I replaced the camera cable and now it works.
